It is currently Sun Aug 03, 2025 3:20 pm
PostPosted: Tue Jan 06, 2009 7:42 pm
I built a new jig for my new Bosch Colt today.It should help make nice channels for my rosettes.
PostPosted: Tue Jan 06, 2009 8:21 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Looks good. I love the bright color. I just completed mine about
three weeks ago, but it's just ol plain white...I am planning to make
use of it for the first time this week.
Gene
PostPosted: Tue Jan 06, 2009 8:38 pm
Thanks,I still have to get a telecaster knob for it.I thought i had one around here,but can't locate it.I'll have to start another guitar so i can try it out.Good luck with yours. Mark
PostPosted: Tue Jan 06, 2009 8:49 pm
First name: Danny
Last Name: Vincent
Looks great Mark. Make sure the height lock clamp is tight on your new Bosch. I just bought a new one and it appeared to be pretty tight but not so. [xx(]
PostPosted: Tue Jan 06, 2009 9:01 pm
Look pretty good Mark, I do notice a couple of things though.
Your router is only mounted with two holes, and holes at the back only. I don't think this will move side to side at all but it might tilt (ever so slightly) upward when the router is on (vibration) so you might want to secure the front of the router somehow. On my Bosh colt, I just drilled and taped new holes (nice thing with the aluminum base) inside of the guide rods.
The other thing is the adjusting rod looks like you've drilled it on center and not above center. That's ok if you just put a couple of nuts on the end and tighten them up, but I'm not to sure if the tele style knob will fit, the diameter may be to big.
PostPosted: Tue Jan 06, 2009 9:08 pm
You can get the Tele knob from Stewmac.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Tue Jan 06, 2009 9:41 pm
It's mounted with all 4 holes. That's why you see 4 holes drilled in the yellow base.The two front ones are under the rods that run through the base. i didn't have to drill on the bosch base that way. I wouldn't just mount with 2 screws.I also offset the center rod so a tele knob will work.
PostPosted: Tue Jan 06, 2009 11:37 pm
I Like that orange! Flashy! Mine is a 7310 and I cut the part of the base over the cut out off because it bothers me obstructing the bit view.
PostPosted: Tue Jan 06, 2009 11:51 pm
Cool, that's all good than Mark. Sorry if I sounded "holier than thou", it wasn't meant as anything other than what appeared (only from the pictures) may have been something missed.
Chris, I did the same thing with my colt. Nice and open to see what's going on in there now.
PostPosted: Wed Jan 07, 2009 12:20 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Cool jig! [clap] [:Y:] [clap]
I'm going to have a go at making something similar, but with a built-in digital scale for 0.001" precision.
I'm a bit fed up with setting my Stewmac Dremel circle cutter jig by eye.....
Dave F.
Cambrian Guitars
PostPosted: Wed Jan 07, 2009 9:18 am
That's all good Rod,I know it's hard to tell from pictures sometimes what your really looking at.I think it's going to be a big help when doing future rosettes.The one i was using was hard to adjust unlike this one which has sort of a fine adjustment built in.
PostPosted: Wed Jan 07, 2009 12:31 pm
They are not at all difficult to make. I encourage you to make your own. See the exact plans and parts needed at http://www.wellsguitars.com/Articles/Precision_Router_Base/Router_Base.html.
Sylvan
PostPosted: Wed Jan 07, 2009 8:56 pm
There is also a tutorial in the tutorial and video section.
Users browsing this forum: DennisK and 38 guests
